DenDirect Report post Posted 06/19/2006 10:15 AM Good day all, I have a quastion we use here voiceguide and it all works perfect. But the thing we want to have is that people can type there number in and that the number is exported to an MS exel file like *.xls or *.csv is this possible? i know that they can type there number and that it is beiing verifyed but i want to export it. Please HELP !!! Thanks, Regards DenD Share this post Link to post
SupportTeam Report post Posted 06/19/2006 01:04 PM There are some examples of reading/saving from/to Excel files using VBScript in the help file. See: http://www.voiceguide.com/vghelp/html/modVbs.htm Share this post Link to post
Guest rajendrarajsri Report post Posted 06/20/2006 10:31 AM Hey, If you dont want to go to net, you may also find it in your machine if Voiceguide inatalled. Start-->Programms-->VoiceGuide-->User's Guide-->Modules References-->RunVBScript You may find here so many usefull vb scripts. rajendrarajsri@yahoo.co.in Share this post Link to post
DenDirect Report post Posted 06/20/2006 01:03 PM Thanks but when i type this in the vb script: Const ForReading = 1 Const ForWriting = 2 Const ForAppending = 8 set fso = CreateObject("Scripting.FileSystemObject") set tsFile = fso.OpenTextFile("C:\LogCalls.txt", ForAppending, True) tsFile.WriteLine "$RV[EnterClientNumber]" tsFile.Close set tsFile = Nothing set fso = Nothing Than it still doesnt work the file logcalls.txt stay's empty?? any idea what i do wrong? Regards DenD Share this post Link to post
fluffybunny Report post Posted 06/21/2006 10:27 AM If you are simply writing a number to an Excell spreadsheet (i.e. not reading information from the spreadsheet to be spoken to the caller) then you could use the DDE Send module instead of getting wrapped up in VBS. This module sets up a DDE link to the spreadhseet and can write values to specific cells in the sheet. Its cheap and cheerful but seems to work. Share this post Link to post
Guest rajendrarajsri Report post Posted 06/24/2006 06:50 AM Hello, This script will work only when the file exist. If the file does not exost then you have to open the file "for writing" instead of "for appending". I think this will work. rajendrarajsri@yahoo.co.in Share this post Link to post
